wiring help needed for swap
Old 04-26-2008, 07:29 PM
Omec's Avatar
Exclamation wiring help needed for swap
im finishing up my M6 swap and have a wiring questions. tried posting in the sticky but no responce. ive got an m6 ecm and wiring harness and not sure how some of the wring is going to work. now from what i can figure the A4 uses the big park switch undet the console for back up lights, starter control and so on. and i see the wiring "how to" for when the a4 harness is being used. using my m6 harness and ecm will i have back up lights w/o doing any wiring inside? as far as i can tell i should, and all the other tranny sensors should work as well. the only thing i cant see working is the two clutch switches. not sure what i should do w/ those. am i running wires from the harness that comes into the car over by the pass kick panel to the switches? also w/ the stock wiring there for the a4 stuff still there, is it going to screw w/ the ecm?
thanks for any help!
