do i have to cut the floor to fit the t56 on the 67?
Old 04-26-2008, 09:52 PM
59 camaro's Avatar
Default do i have to cut the floor to fit the t56 on the 67?
i heard from some ppl that u have to cut the floor to fit a t56 in the 67 camaro is this true...if someone has pics can u plz post them...thanks for the help
Old 04-27-2008, 12:30 AM
1442's Avatar
i have a t56 in a 69 camaro didnt have to cut,only for shifter thats it, summit universal crossmember
Old 04-27-2008, 07:24 AM
merriman44's Avatar
Should not have to, no.
Old 04-27-2008, 07:54 AM
Shawn MacAnanny's Avatar
Just for the shifter. Here is mine, transmission mounted all the way up in the tunnel. ATS plates. You can see where the origional shifter hole was for the 3 speed manual and OHC car. The hole the previous owner made for the TH400 auto shifter landed right where i had to cut the bigger hole out. Maybe that was the origional shifter hole, i'm not too sure.
Attached Thumbnails do i have to cut the floor to fit the t56 on the 67?-inside.jpg
Old 04-27-2008, 09:33 AM
Rodder's Avatar
Here's a pic of mine (ATS plates & crossmember) where you can see the original '68 shifter hole and how I had to extend it:
Old 04-27-2008, 09:38 AM
Rodder your transmission is in backwards :-D What shifter is that? It looks pretty short? Maybe my transmission just sits up higher though.
Old 04-27-2008, 10:01 AM
Rodder's Avatar
It's the Hurst Billet/Plus #391-5061. The stick it comes with (pictured) is Hurst #538-7238, which is 7.50" from the bottom shift attachment hole to the center of the **** and is completely straight. I'd like something that positions the **** and 2" lower and 2" farther back.
Here's a pic of my interior mostly assembled, think the shifter is in 1st gear:
One of these days I'm going to try the Steeda handle (really short!) from my '00 Mustang and see how I like it in the Camaro. I already redrilled it to fit the Hurst Billet/Plus that I run on the T45 in the 'stang, so it'll bolt right to the Hurst in the Camaro. http://www.steeda.com/products/steed...ter_handle.php
Old 04-29-2008, 09:34 PM
59 camaro's Avatar
thanks for all the help and pics guys...
Quick Reply: do i have to cut the floor to fit the t56 on the 67?
