Tools & Fabrication - Electric Impact?
View Full Version : Electric Impact?
MetallicaMatt
04-27-2008, 12:32 PM
Hey guys,
I'm looking into buying an Electric Impact wrench. But not to use it as an impact...
I put 3" studs all the way around, and I want to use this, or maybe even my cordless drill (?) to run the lug nuts on and off, and then go around and tighten them with my torque wrench
I want to use this, so when I'm at the track, or not near a compressor, I can use the cordless
what do you think? opinions? what are some of my options?
I want something on the cheap, with a battery that will last taking the tires on and off twice before a charge.
again, CHEAP since I'll only be using it for this...
02NITROUSLS1
04-27-2008, 01:52 PM
Hey guys,
I would buy a Snap-On electric Impact. I used to have an 18v Matco and it had problems breaking lug nuts loose. I traded it in for a Snap-On and have yet to have any problems removing lug nuts when changing tires at the track...
02NITROUSLS1
04-27-2008, 01:54 PM
BTW, I only use mine at the track. I think you'll get what you pay for when it comes to electric impacts. Mine came with 2 batteries and I can use the same battery for several cars when at the track.
BigKap94z
04-27-2008, 02:46 PM
The Snap-On 18vcordless impact has the highest torque rating and is a killer impact. The Milwaukee 28v is also a very good impact as well. I was in a pinch and bought a Jegs brand cordless impact that is pretty cheap and has a decent torque rating for the price. With it I still struggle with lugnuts at times. It serves the purpose for me, but If I was using it alot more I would just spend the money to get the Milwaukee or better yet the Snap On.
MetallicaMatt
04-27-2008, 04:53 PM
well I figured I would use my new ginormous torque wrench to tighten/loosen the lugs
then just use the cheapo impact to run the lugs off instead of doing it by hand.
I know your not suppose to use a torque wrench to loosen things, but mine has a reverse option on it and is good to 200 ftlbs...so it should be plenty fine
VETTEX2
04-29-2008, 11:52 PM
I've used the Snap-on for pit stops
it is the best battery impact I've used
I also have a Milwaukee 110v impact that works good too.
nncfan8
05-02-2008, 12:01 AM
pep boys has a goodyear 24v that is pretty good ($79-$99) not cheap but inexpensive compared to others mentioned.;)
1BADAIR
05-10-2008, 09:22 PM
dont use a torque wrench to loosen things.
If you are gonna break them loose first I would get a craftsman or milwalki 3/8.
I have a 1/2 I/R that I use everyday and atthe track also
1QWIKBIRD
05-10-2008, 11:07 PM
I have a DeWalt 18v that I picked up used off the board here and its fine for what you describe, but it will not break lug nuts loose that are torqued to 100lbs. The battery will easily swap tires for 2 or 3 autox events, no problem. I carry a breaker bar to loosen and a torque wrench to tighten and use the gun to run them on and off for the same reason as you, long studs. Not what I had intended, when I bought the gun, but works just the same.
In comparison, my buddy has a Snap-On and that gun does it all no problems, not cheap though.
If all you want is to run lugs on and off, get a 3/8ths gun. And like others have stated, don't ruin your torque wrench by using it to loosen, not intended for that. In a pinch, maybe, but not on a consistent basis.
Update: I broke down and bought some impact sockets and now the gun is unstoppable. Used it on my 3/4 ton Dodge to change a flat and it had no trouble breaking loose all (6 or is it 8) lugs and torqued to 125ft/lbs. I guess lots of torque was being lost in the standard sockets, shame on me.
Chris
CTSmechanic
05-11-2008, 12:52 PM
I have a Snap On 1/2 Elec and love it.... I have used many others such as..... IR..(guns suck and batterys are even worse) Milwakee guns too big.. and cumbersome might have a problem with it reaching into the wheels....Dewalt is large as well but good quality... I'd look at Ebay theres used Impacts all over the place... Im not really surw why you'd not tighten the lugs with the impact and use the remove'em..... I've done it hundreds of times.. never any probs...
onecamaro1
05-11-2008, 01:38 PM
They are awesome at pick and pull places.
zman1969
05-13-2008, 12:47 PM
I have a full set of 18v Milwaukee cordless- I started with the impact for the junkyarding- great way to remove pinion nuts , carriers ect - little heavy but works good . My buddy got the 28v with the lithium batterys that last alot longer but IMO not worth the $ for me to upgrade - yet! also use the sawzall and circular saw and the hammer drill to death around the house - great investment -about 600$ for the kit and impact -I almost dont use my air compressor anymore even when rebuilding rear ends at home. just wish they had a 3/8 impact that works on same battery(takes a a 14.4v) dammit!
chromeplated500
05-18-2008, 08:47 PM
I like the Snap-On 18vcordless its pretty impressive. At first i was skeptical.. and dissapointed with its weak sound. but it works great.
fastgmc98
05-18-2008, 11:28 PM
I bought the new matco cordless impact and WOW! I got rid of my Snap-on. Battery charges faster and I can use it almost all night at the track...
99mongooSS
05-18-2008, 11:29 PM
I Am a professional mechanic at a performance shop, and I will tell you right now my favorite tool is my 14.4 volt makita 3/8 impact its a bad bitch! I can torque a lug nut to 100ftlbs and it will break it loose. Don't spend all that money on snap on crap unless you have to their 18v is not that much better and its heavier...mine will do everything the snap on 3/8 elec. impact will do and it holds it charge longer. A guy at work has the snapon one and we did the pepsi challenge with the two and mine stood the test right with his except when his battery started running low he lot all power my had almost full capabilities untll about 30% life left on the batt.
chvypwr31
05-31-2008, 04:08 PM
i got an 18 volt matco 1/2 inch impact it works great never any problems i think its capable of up to 350 ft lbs, and they also make a 3/8 model which is pretty strong too.
jmdale1984
05-31-2008, 04:18 PM
Just throw a 1/2" breaker bar in the hatch, and a cordless drill with a 3/8" chuck in it.
98trans-am
05-31-2008, 05:13 PM
i too have been looking into a cordless impact for the same reason. ive talked to the snap-on guy at work and there 18v is rated at 550 ft/lbs in reverse and 350 ft/lbs to tighten. mac,matco and makita will have cordless impacts within the same range to tighten. im not sure about loosening though but i think snap-on is the only brand to rate it that way.
redbandit98
06-01-2008, 08:28 PM
im with him, if you want to do it cheap. I would just take my dewalt cordless drill, (puny little 12 volter) bust them loose with a breaker bar and finish them off with the drill. Then snug em up with the drill and finish with your breaker bar. There really is no in between in my eyes. I mean if you buy a cheap impact, your gonna have to re-torque them anyways. So your still in the same boat as you were with having just the drill. ITs either get a cheap drill or one you already have, or pony up and get a 500 dollar impact..(i dont know how much they really cost but im sure they are $$$:chug::chug:)
FWIW, I also am a fan of makita shit. Ive used and abused lots of it, and it usually holds up. Milwaukee stuff is pretty good too.
Z06PSI
06-12-2008, 01:22 PM
O.k. I have settled on the Makita 18V LXT system for the ratchet and the impact. Why don't they make a mechanics combo pack?.....:eyes:
tim99ws6
06-12-2008, 04:17 PM
Honestly, I bought a Costco Kawasaki Electric Impact. It was not ver $$$ at all. I just keep it and my torque wrench together. I would rather break the studs free and finish up my torque with the torque wrench and a breaker bar, and just snug them down or run them off the extended with the impact. I see no point in a high $$$$ impact.
not_my_z
06-12-2008, 09:49 PM
Good choice. I just picked up the Makita LXT tools too (2 drill/drivers, impact, reciprocating saw, circular saw, flashlight). I really like them. The batteries charge in 30 minutes, last forever, and they don't self-discharge when left out.
Z06PSI
06-17-2008, 08:26 AM
I got the 90 degree BTL60 ratchet and charger with two batteries for 350.00. going to pick up the angle grinder and the impact next. Should be here tomorrow.
Z06PSI
06-21-2008, 05:15 PM
Let me just say that this Makita BTL 60 is a must have. I can't wear the thing out.
allblacksrt4
07-11-2008, 02:36 PM
not cordless. but i have a chicago electric one and it works great. i have had it for 2 years and it was only $29.99 from Harbor freight.
squee
07-11-2008, 06:12 PM
I was at Lowes the other day and the Hitachi they had was very impressive.
Z06PSI
07-14-2008, 07:58 AM
Getting ready to pick up the BTL's mate. The BTW 450. I will give a review after I am done.
