New LS1 Owners - Newbie Tech - buzzing sound
bobbyd
04-28-2008, 08:23 AM
well when i hit or put my foot on the gas pedal I can hear a buzzing sound. if I let go or remove my foot from the pedal the sound stops.
what could be the cause? driveshaft? rear end?
what could I check.
Like I said I dont even have to hit the gas as long as my foot is touching the pedal and putting a little force on it it will make the sound.
95GreenZ28
04-28-2008, 10:55 AM
Buzzing? Hmm maybe a u joint.
95GreenZ28
04-28-2008, 10:56 AM
Have you checked for play on the driveshaft?
tylerdj
04-28-2008, 10:59 AM
Buzzing? Like an electrical buzz?
bobbyd
04-28-2008, 11:15 AM
nope not yet. how exactly would you check for that?
probably isnt a buzzing sound but it makes a sound like a whinning sound I guess?
bobbyd
04-28-2008, 11:16 AM
nah this is more like a whinning noise I guess?
tylerdj
04-28-2008, 11:18 AM
If it's a whining sound it's more than likely your differential.
95GreenZ28
04-28-2008, 11:28 AM
Grab your driveshaft and twist it from side to side. If you have alot of play there it is prob your u joints.
bobbyd
04-28-2008, 11:45 AM
will try this later today and report back
z28_YOU_HO
04-28-2008, 11:47 AM
edittt
tennz28
04-28-2008, 11:55 AM
I had a high pitched wine noise and it got louder as I pushed on the gas and softer as I let off the gas. It was coming through the speakers so I knew it was electrical it turned out my battery connections were corroded to hell. After i cleaned them off the noise went away......not sure if its the same noise you have going on just thought id share.
LS1>girlfriend
04-28-2008, 12:00 PM
ring gear teeth are sharp....be careful
bobbyd
04-28-2008, 12:12 PM
hmmm will try this aswell since that sounds about right the more you hit the gas the louder it got and the more you let go the softer It got.
tennz28
04-28-2008, 12:36 PM
Yeah it was driving me crazy, clean the terminals and put some anti-corrosion spray on it. Worked for me...
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
