New clutch: Pedal Wont move
Searching didnt find me what I was looking for...
Put in a new clutch , spec 2+ with flywheel. Put the trans back in in and went to test the clutch pedal out, and its hard stuck- can barely move it ½ inch ( thats just pedal spring slack )
Car had a crappy stock clutch, 16,000 miles, 2002.
I am thinking there is something wrong with the slave, the kit from spec came with a replacement TO bearing for the slave which I installed along with a shim.
Havent tried to start the car yet. Should the car be netural started while it is like this?
