Drag Racing Tech - what will i run with these mods:
67camarors
04-28-2008, 03:51 PM
i know its been talked about a million times but im still curious. i have 3.23s shift kit, custom built 3000 converter, internal transmission work, hooker long tubes and true duals dumped before the axle with pro flo twister headers. i also have sticky tires so traction isnt a problem. car went 13.47@104 stock.
Slow00ls1T/a
04-28-2008, 06:25 PM
12.55@ 107
DanZ28
04-28-2008, 10:27 PM
12.8 @ 106
daniel6718
04-28-2008, 11:16 PM
12.5 at 108
DanZ28
04-28-2008, 11:21 PM
We need a money pool going here :).
67camarors
04-29-2008, 12:36 AM
haha no kidding. i dunno if it matters bu i live in washington sate and the corrected altitude here is like less than 100 feet
DanZ28
04-29-2008, 02:47 PM
The DA will change by the hour, but phisically you should be at a fairly low altitude in Washington and can make a big difference in ET and MPH if you can get into the negative DA.
I had your exact same mods but had a 3500 stall, went from 13.4 @ 104 to 12.7 @ 107 on a good day. But different tracks seem to vary around the country and I run at a slow track.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
