91.5 vs gt4788
Old 04-28-2008, 05:44 PM
bumpin_records's Avatar
Default 91.5 vs gt4788
I have the money to buy my turbo now. Im now trying to decide what turbo either a 91.5 or gt 47-88? I have a 370 ci engine , dart cnc pro 1 heads, carb intake ,nw 90 tb, im going witha power glide. what turbo would make the most power?
Old 04-28-2008, 05:51 PM
Chiet_SS's Avatar
Go with a BW 88mm S488
Old 04-28-2008, 06:04 PM
how much power do that turbo make? any wasy im getting a deal between the two thats why those 2 are my choice.
Old 04-28-2008, 06:39 PM
veee8's Avatar
My Gt47-88 t6 1.08 is capable of 1500 hp I believe. 370 ci. too.
Old 04-28-2008, 06:49 PM
Chiet_SS's Avatar
The bw 88mm is good for 160#s per min, or 1600 HP
Old 04-28-2008, 08:06 PM
LS1TECH Sponsor
DrTurbo's Avatar
Uhhh BS...plain and simple. Who ever told you that is highly mis-informed. Our S88 will spank a S488 that uses the old 7 blade comp wheel, and hell it won't make 1600hp.
Old 04-28-2008, 08:07 PM
LS1TECH Sponsor
DrTurbo's Avatar
Bwtween the 2 you just mentioned....the GT4788 would be a better match if you plan to ever put it on the street.
Old 04-28-2008, 08:20 PM
BoostnTBSS's Avatar
I like the Y2K's
Old 04-29-2008, 03:00 AM
well drturbo this is the deal. I am gonna drive it on the street. Cruzing that is. meaning im not concerned about how fast it boost up on the street. Im not trying to get a ticket. as far as the track i want to run mid to low 8's if possible. I will have a trans brake. I see you have turbos as well. the two i have asked about i can get for like 1500. If i have to spend a few more hundred to get even a better turbo i really dont mind so what do you have or suggest? thanks
Old 04-29-2008, 05:58 AM
Fireball's Avatar
at the 1500-2000 dollar range, I'd take a look at the S91 also
Old 04-29-2008, 09:37 AM
LS1TECH Sponsor
DrTurbo's Avatar
If that is the type of setup your are building then yes you definitely want something in the S88, S91 or GT47 range. Give us a call or shoot me a PM, I will see what I can do for you.
Old 04-29-2008, 11:12 AM
Chiet_SS's Avatar
My info comes directly from a Borg Warner dealer!
S488 V-Band Outlet 87/96 Turbine Wheel 1.32 A/R
Turbocharger Name - S488
Compressor Wheel Inducer - 88mm
Turbine Wheel Inducer - 87/96
Turbine Wheel Trim - 96
Turbine Wheel Part # - 410100-3
Turbine Option - Outlet - V-Band
Turbine Option - Inlet - T6
Turbine Option - A/R - 1.32
Horsepower Rating - 1600
Old 04-29-2008, 11:16 AM
LS1TECH Sponsor
DrTurbo's Avatar
That is wrong info.....plus they don't make an 88 for a 4XX series unit. Even the higher series unit which is based on a 5XX platform will barely support that. Also that turbine wheel will not support it. Lots of hype out there on units. Call Jose (jz 97 ss 1500) and talk to him he can direct you on what you need for that type of power.
Old 04-29-2008, 11:25 AM
Chiet_SS's Avatar
it very well could be, i was mearly telling what I had seen and been told.
Old 04-29-2008, 11:26 AM
LS1TECH Sponsor
DrTurbo's Avatar
No problemo....
Old 04-29-2008, 02:04 PM
stevewix's Avatar
granted my setup isn't optimal, just a low comp. street motor with a .96 a/r housing; but at 22psi it was making 725's at the tires through an unlocked converter and notoriously stingy MD1750.
Do the S91 and let me know how it turns out so I can finally make up my mind on changing turbos.
Old 04-29-2008, 02:47 PM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,099 Likes on 721 Posts
867rwhp, 25psi, 8:1, 348ci, GT47-88, A3. Buy my kit and then I can go bigger. Much bigger.
Old 05-09-2008, 08:59 PM
I just got the 91.5mm my god that turbo is bigggggggg
Old 05-09-2008, 09:37 PM
Frank02L's Avatar
We went 5.82@119 with a stock LQ4 bottom end with (outta the box) L92 heads with a GT47-88 at 3265lbs. Thats just a hair over 9.0s in 1/4. Thats on the 10lb wastegate spring. That said, I do think that the PT91 is a better choice for a more of a "race car" setup like you are talking because the exhaust wheel is bigger.
Old 05-09-2008, 10:07 PM
Mr.MartyStone's Avatar
Try the 98mm Hell I wanted to go 106, but I didn't have the budget to outfit the car for it.
Marty
Quick Reply: 91.5 vs gt4788
