trans coolers, 1? can i run 2? any advantages or disadvantages?
ok im new to the auto world, but im goin to be runnin a th400 on the street. it has a tbrake and i was told they make them run a little hot. but whats the best cooler, and can i run two coolers without any problem? would runin 2 cause flow or presure probs?
LS1TECH & Trucks Sponsor
I ran two aftermarket coolers with the stocker bypassed. I probably will on any car I build
__________________
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
i have used an a/c condensor as a cooler before It was on a truck with 44 inch tires and a 3500 stall it was the only thing that kept it cool lol
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
lol held an extra 5 quarts of fluid too
__________________
so to be really safe i could get two big coolers and be ok? or would one big one with an electric fan that is temp controlled be good enough. i just need to be able to go in stop in go traffic in 100+ degree heat without any probs!
If you run 2, try to set them up in parallel (Y-block to both with hot oil, Y-block back together back to the tranny) instead of serial (out of one into the other). They will shed more heat and have 1/4 the restriction and psi loss.
Jim
Jim
Performabuilt has really good info on their FAQ about running multiple coolers.
Jim
