Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
Valve spring question
Old 04-29-2008, 05:02 PM
84z28Camaro's Avatar
Default Valve spring question
What springs would work well on http://www.competitionproducts.com/p...ber=RHS12410K1 that could handle .6 lift and not require much modification if any?
Old 04-30-2008, 04:26 AM
1997bird's Avatar
What kind of cam will you be running? Hyd,Solid,Hyd Roller, Solid Roller? If you have a part number that would help as well.
Old 04-30-2008, 07:30 AM
Hydraulic cam.. don't have a part number on the cam yet as it's going to be custom. I'll probably be fine if I can handle .55 lift with the springs as well.
Old 04-30-2008, 09:32 PM
1997bird's Avatar
This spring is what you will need for your application. You don't have to run this brand of springs if you don't want to, but make sure your installed height is the same & the spring pressures are about the same. http://store.summitracing.com/partde...881+4294774833
Old 05-01-2008, 10:09 AM
Cool thanks. What's the max lift for those out of curiosity?
Old 05-02-2008, 03:46 AM
1997bird's Avatar
.600" lift
Old 05-02-2008, 07:45 AM
Thank you
Quick Reply: Valve spring question
