Loud banging noise on bumps
Old 04-29-2008, 06:51 PM
Jalbert's Avatar
Default Loud banging noise on bumps
Since I've changed my lower control arms and panhard rod when I hit a bump or even cracks in the road there is banging noise from the diff area, do I NEED SPECIAL LUBE?
Old 04-29-2008, 08:02 PM
BobDoLe's Avatar
are the lca's poly/poly? did you not lube them up before you installed them?
sometimes the lca's bind and will do that, but i wouldn't call it a loud banging sound.
Old 04-29-2008, 11:51 PM
95GreenZ28's Avatar
I agree with bob sounds like you need to grease all your serts
Old 04-30-2008, 12:24 AM
djsanchez2's Avatar
Did you torque them down to 75 ft. lbs.? Some also recommend up to 100 ft. lbs. Mine knock when they come loose too. I always forget to use friggin locktite.
I used the synthetic lube from Energy Suspension that came with my T/A. Works great, plus I had extra so i said **** it...
Old 04-30-2008, 02:18 AM
cookba's Avatar
my car bangs over every little thing on the road. it all started when i got my rod ended RCA and Panhard.
Old 04-30-2008, 05:49 PM
The Guz's Avatar
Are you lowered? I had a loud banging noise on the passenger side. The passenger side was hitting the bump stop. I read a lot of threads on the bump stops and got some info from a few others. I switched over to the Z28 bump stops and the loud banging noise has since gone away. I do get it when I hit a large bump.
Quick Reply: Loud banging noise on bumps
