T56 help...
Old 04-29-2008, 09:42 PM
DopdBrd's Avatar
Default T56 help...
So I have a few problems right now. First off I need a new Master Cylinder and possibly a clutch, and now I believe my tranny is in need of a rebuild.
Here is what I need,
I want the tranny to be able to handle around 700hp and about 800 ft lbs. Right now I plan on spending about 2000 for a new master, spec stage 3+ clutch, and the tranny rebuild.
I took a transmission class back in college and rebuilt A LOT of 4 and 5 speed trannys. I am pretty sure I can do it myself (i'm pretty mechanically inclined) and like the fact that I do ALL the work on my car myself instead of relying on someone else to do it. So, is there some type of manual I can get to show dissasembly and reassembly of the T56? I basically just need something to show me where all the parts go since I really can't remember what I did yesturday.
Also, where can I get a decent priced rebuild it? Now just because I planned on spending 2000 doesn't mean I really WANT to spend that much.
Old 04-29-2008, 10:10 PM
Allvette's Avatar
The manual is available here as a PDF file. There are several forum sponsors that can help with the parts you'll need. Six Speeds Inc. is one of the more popular ones with a great reputation for customer service and expert advice.
Old 04-29-2008, 10:21 PM
DopdBrd's Avatar
Hey thanks man. Like I said I would like to spend as little as possible.
Old 04-29-2008, 10:32 PM
chuckyt1's Avatar
Call Amber at Six Speeds Inc. She will help you out and has all the parts you'll need...
Old 04-30-2008, 08:38 AM
gcpoland's Avatar
http://www.ddperformance.com/
Have the parts in stock and shipping the same day. Call them and they can set you up with everything.
Old 04-30-2008, 09:51 AM
Tally TransAm's Avatar
im in the same boat as you, i have the t56 service manual but i think i also have another rebuild manual on my comp at home. ill check when i get back in an hour or so
Old 04-30-2008, 09:57 AM
DopdBrd's Avatar
Thanks man I appreciate that.
Old 04-30-2008, 10:15 AM
jmm98LS1's Avatar
The manual that Allvette posted is the one I use, it shows you where everything goes with lots of good exploded pictures.
