Comp Cams 7.4" push rod
Old 04-30-2008, 12:55 AM
verano29's Avatar
Default Comp Cams 7.4" push rod
I'd like to buy the best comp cams 7.4" pushrods for my 98 vette. Unfortuneatly I have absoultely no idea what part number this is. Can someone help a member out and tell me what part number I'm looking for? Thanks!
Old 04-30-2008, 01:02 AM
verano29's Avatar
Possibly I'd like to go with 7.425. I know they make these, I just don't know where to get these nor what part number that are. I want the hardened crome-moly super turbo-liscious gold platinum premium pushrods
Old 04-30-2008, 01:07 AM
mvvette97's Avatar
7955-16 for the 7.4 pushrods. If you have the stock cam then you don't want the 7.425 because you will have too much preload. Go with the 7.4
Old 04-30-2008, 08:16 AM
verano29's Avatar
I actually have the same cam you do. I have dart pro1s (unmilled), LS2 gaskets (.051"), comp cams 850-16 lifters, comp cams 228/230 .571/.573 112. Using a pushrod length checker I determined that with a .075" preload I need 7.4" push rods.
Quick Reply: Comp Cams 7.4" push rod
