Want a new transmission mount, have some questions
Ok here's the deal. I have a poly transmission mount that I had on the car for a while. I got tired of the vibration and noise from it and went back to the stock mount. I like it a lot better. I had no idea how much noise/vibration the poly was actually making until I switched back. I had gotten used to a lot of it, apparently.
I'm wanting to get a stiffer transmission mount like the 1LE, but not as stiff as a poly one because that was too much. I've been reading and looking for part numbers on the 1LE mount and I have found a whole bunch of different part numbers and read that the one they are selling now doesn't really fit f-bodies correctly and can damage the transmission.
Also, am I right in thinking that the WS6 came with a different (stiffer) transmission mount than a normal Trans Am?
So does anyone have the current part number for the 1LE transmission mount or know where I can get one?
as far as i know 98-02 ws6's were nothing but an apperance package and possibly a stiffer spring rate but dont quote me. my 02 ws6 deff doesnt have the 1LE mount. i think you should look for a mount for an lt1 WS6 or SS. what about just doing poly motor mounts and leaving the stock trans mount?
What brand poly mount were you running? I've tried energy suspension on 2 different occasions and couldn't take the noise or vibration. I now am running a 'prothane' poly mount and it is just awesome. Much less noise and vibration then the ES one but still have the stiffness.
i put the prothane one in and had horrible vibrations and well my tail shaft broke on the dyno yesterday im going to check my pinion and tire balance asap to see if that could be part of the problem
Get your driveshaft BALANCED!
Please don't argue and question "How can a driveshaft go out of balance?"; just have a DS shop balance and straighten it - you'll be fine after that!
Sorry for adding to an old thread, but I just put an energy suspension polly mount in to replace the stock one. The vibration is killing me!!! You say that the real problem is that my Drive shaft is out of balance and it does not have to do with the mount? If so, where can I get it fixed around North eastern Oklahoma? I live in a small town, and when I take my car to the hillbilly shops for this stuff I get laughed at, and told that wouldn't cause a problem... Any input would be great!
CARTEK Racing
I have had an Energy Suspensions mount for 3 or 4 years now. I honestly don't think I noticed much more vibration and noise coming from it then when I had the 3 stock ones that I BROKE!.
Dunno what to tell you...
While the poly ones tend to transmit a bit more noise, they are not all that much louder than stock and really don't add to the vibration. I've compared stock, energy and prothane and I can tell you that the ES one is stiffer than the prothane. The ES one if installed per instructions is brutal. The preload plate with the bumps on it makes it fairly stiff. To get the ES near stock feel, you need to shave the bumps off and not use the preload plate.
The prothane one is stiffer than stock, but less than the ES mount, even modded. The design of it is different enough to give a stiffer than stock feel.
Both poly mounts will transmit noise from the transmission, if you have a built transmission it will sound more or less like a rattle when you do something like rest your hand on the shifter while driving.
2001, body, downshifting, energy, issues, ls1tech, lt1, mount, performance, plate, poly, preload, suspension, trans, transmission
