Midwestern Members - E-Check help NE Ohio
gn4life
04-30-2008, 02:08 PM
Heres my delima....
My ls7 clutch kit and catless exhaust goes on Monday....
However my car is clutchless right now and non drivable...
Do any fellow LSx ers work at an Echeck place or know somebody who might throw me a bone....If u dont feel like saying in public please PM me.
Or whats the best e check place to take my car to in NE Ohio....A place were they may be to lazy to really check or might be persuaded for a small fee :nod:
I dont feel like waiting at least 3 weeks for collectors plates because
A. You can no longer get them for a stock 2000 Camaro SS
B. You have to have $5,000 in receipts...Which i probably do but I am sure they wont be honored hassle free:mad: so there is no guarantee this will work
Any help will be greatly appreciated!!!
Thanks
gn4life
04-30-2008, 06:33 PM
Oh and what would I need to do to pass without cats if I have to, I heard it is very plausable
QuickSilver
05-01-2008, 11:56 AM
if the codes are deleted out of the pcm that will help. but you will still fail the visual check for the cat. I have mine registered in a county w/o e-check. You could weld just a convertor shell on, then make sure all the codes are gone and you should be ok. but if they run the tailpipe test you may or may not pass.
The only other thing you could do is try and get a reciept for over $300 and try and get an exemption.
Josh
gn4life
05-01-2008, 10:23 PM
Josh
Thanks,
What do you mean by an en exemption??? I have reciets over $300 for work done to car including exhaust work... How do i get an exemption???
Subliminal Hit
05-01-2008, 11:23 PM
Thanks
where did you find this info?
QuickSilver
05-02-2008, 08:49 AM
if you fail e check ad show a 300 reciept for repairs to pass e-check they will give you and exemption. it has to be current dated tho.
Josh
gn4life
05-02-2008, 08:53 AM
Subliminal Hit
I called the BMV and this is what they told me as of a few days ago...But I hear different info from alot of people.
Quick Silver
Thanks, but who is in charge of giving out the exemption, the BMV or the E- Check place??? What part of Ohio do you live in?
QuickSilver
05-02-2008, 12:47 PM
im in the akron area usually you go to e-check fail get the reciept then take that back to e-check i think. I dont do e-check i did make up some invoices at the shop i used to run that helped some people get the exemption. but im no longer there.
What are are you located in?
Josh
gn4life
05-02-2008, 01:52 PM
Josh
I'm in Twinsburg.... I just got back from the e-check place in Twinsburg from e checking another vehicle... I asked them they sent me to the EPA building next door... The manager there baisically let me know that it was not going to happen and if so he would make it darn near impossible and he would only issue an "extension" for a brief amount of time... This makes no sense to me... I dont think he can do that... Maybe the Echeck places out by you might be more resonable....
Thanks
QuickSilver
05-02-2008, 02:09 PM
if you fail and spend over $300 to repair the problem that caused it to fail they must give and exemption.
PM me i can point you to a few e-check out this way.
Josh
BRAKE
05-02-2008, 04:33 PM
Get Collector plates, if you have another car in your name you can do it. Bypass E-check all together.
