Fueling & Injection - Plastic Tank With Braided Line
vandal0-0
04-30-2008, 07:09 PM
How are you guys running braided line from your plastic tanks.I run dual walbros intake pumps and stock line.I wanted to go with a -8 feed and -6 return.If anyone has pics that would be great.
Thanks
Brad
MeentSS02
04-30-2008, 08:33 PM
The fittings on the top of the tank are standard 3/8" SAE J2044 fittings. This means that fittings like an Aeromotive 15118 will work.
If you use the Aeromotive fittings, you'll also need an Aeromotive -8ORB to -8AN fitting so you can connect it to a standard -8AN braided hose.
Aeromotive also makes the SAE J2044 fittings in 5/16" (which is the size of the EVAP line if you use that as a return), and those take -6AN fittings.
vandal0-0
05-01-2008, 12:04 AM
I appreciate the help and part#'s I never knew they had fittings like that.I already have the evap as the return so I guess I wont change that.
Thanks
Brad
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
