MDM@SDPC
05-01-2008, 11:20 AM
As you all saw in the post a week or so ago, we have aquired some of the new Pontiac G8 L76 engines. We have now got dyno numbers from this engine with our cam and spring package resulting in over 500HP and 500FTLBS at the crank. Below are the specs and order info on the engines.
Just received! New, direct from GM, 6.0-liter engines with L92 cylinder heads.
6.0L LS2 Aluminum Blocks
L92 Cylinder Heads
L76 (Car) Intake Manifold
Complete Engine – fuel rails, throttle body, ignition coils, flexplate, water pump, factory exhaust manifolds, plug wires, and spark plugs
Choose your T/B design (drive by wire or cable), 24X or 58X crank. Oil pan is front sump design and can be changed for an additional charge or you can install your pan and pick-up assembly. Limited supply!
Stock engine $4895.00 --- includes shipping in the lower 48-states.
Upgraded 500/500 $5395.00---includes shipping in the lower 48-states.
***ADD $500.00 for CNCported heads and 25 MORE HORSEPOWER!!!***
Thanks!
L92 Cylinder Heads
Thanks!
