2 Bar Maf installation
I thought I saw a post on how to install it, but coming up short in finding it again.
I search a few different ways, but nothing.
I have 12580698 Cobalt MAF and I saw something about shaving down a side of the MAF to make it fit a LS1.
1 Post
Like Forcfed said, DO NOT install until you load a 2-bar operating system in the PCM. If you don't the car will run lean as a$$ and give some jacked up looking readings on the scanner. The 2-bar sensor is actually a baro sensor and the stock PCM program can't accurately use the values from it. Once you convert the PCM operating system to 2-bar SD it will work awsome
quick question for me i am switching to 2 bar, i just installed my sts on the car but havent started it or anything and the tuner said they'd rather me go 2 bar so i just installed it...does the 1 bar have to be in there first before they start changing things or is it ok to just put the 2 bar in and have them change it after?
1 Post
ok, what about the V6 Camaro MAP Sensor, will it work on my Stock LS1? because I found out it is broken and the dealership dosn't have it in my country... but some private shops have the V6 Map sensor... what do u guys think? they both say 5V on the outside, and same connector also... but Im worried that I might have the same problem that the BAR measurement is different...
