D1 Procharger Good to how much HP
Old 05-01-2008, 07:18 PM
Ilikeppie's Avatar
Question D1 Procharger Good to how much HP
i am going to put a D1 Procharger on the car and was wondering what it will put out in the way of horsepower before i would need to upgrade to a F series or change out the intercoolers? thanks
Old 05-01-2008, 07:22 PM
nxlude's Avatar
If i recall its 925 (per their website, but others may know more than me.) Intercoolers will be your shortcoming before the D1
Old 05-01-2008, 07:37 PM
01red28's Avatar
from what I have heard 750whp seems to be where it runs out of steam.
Old 05-01-2008, 07:38 PM
Jake@EPP's Avatar
750ish is about the max you can spin one on a loaded dyno. A f1 is better suited to make this range of hp as you do not have to wing it as hard to produce the same numbers.
Old 05-01-2008, 07:45 PM
LS1Tech Sponsor
Slowhawk's Avatar
As ussual it depends on setup.Your could have a poor motor combo and put out 600rwhp or you can have an efficient setup that does 700rwhp on pump gas.Then you can get real efficient with Meth and put out 900rwhp.Matters on the build.
I just had a 98 Z at the shop running the D1 at 8lbs and a 224 Cam,headers.To my surprise it pushed 560rwhp/510tq detuned as far as possible.(customer only wanted 450-480rwhp)I know we would of gone past 600rwhp with the Cam only 98 motor.That motor just ran efficient.
Old 05-01-2008, 09:35 PM
Ilikeppie's Avatar
nice i thought about a F1A but how will the driveability be with this unit also i would need a fmic with this one as well but will it work without doing the bottom end of the engine as long as i keep the boost to about 8lbs
Old 05-02-2008, 12:12 AM
01red28's Avatar
driveability is fine. I believe that it is kind of hard to pulley it down to that low of boost, the F1-A does create a little more heat then its little brother and since you would be buying a bigger blower for use in the future I would go ahead and buy a FMIC so you do not have upgrade that in the future. But If you never plan to go over 8 pounds on a stock bottom end, then there would be no point in buying a F1-A you would be wasting power to spin a bigger blower for nothing. and it would be out of its efficiency range.
Old 05-02-2008, 04:41 AM
EPP
EPP's Avatar
Normally the least amount of boost you can produce with an F-1A is 12 psi or so. You can have a custom pulley made by ASP for the head unit, something in the 5.75 range will slow down the blower to keep boost around 8 psi.
Here is a Trans-Am with a 402 that we got 757 rwhp out of a D-1SC.
http://www.exoticperformanceplus.com...Car.php?car=42
Here is a Corvette with a 346 that we got 740 rwhp out of a D-1SC.
http://www.exoticperformanceplus.com...Car.php?car=40 Bob
Quick Reply: D1 Procharger Good to how much HP
