1-2 shift clunk
Old 05-01-2008, 09:29 PM
formula4437's Avatar
Default 1-2 shift clunk
my car has a clunk sound at the 1-2 shift and sometimes at the 2-3 shift under moderate acceleration. I did all upgrades in my sig 300 miles ago.
i think it may be my trans mount but dont know for sure any ideas.
Old 05-01-2008, 09:50 PM
Blackhawk777's Avatar
Definately trans mount.
Old 05-01-2008, 10:33 PM
LS1Silverado05's Avatar
Trans mount would be suspect #1 thats for sure. Double check the TA mount too.
Old 05-06-2008, 10:45 PM
99redm6Z28's Avatar
the transmission mount is most likely not the problem. it sounds like you have clutch chatter. i have the same problem and i have changed the trans mount already and the problem is still there. you have to change your clutch and either resurface your flywheel or get another one. hope this helps
Old 05-12-2008, 10:13 PM
Problem is it's an A4 tranny. Been there, done that. Check that trans mount.
