Brake warning light
Old 05-01-2008, 10:43 PM
95hawk467's Avatar
Default Brake warning light
Finally got the car up and running, trying to work out some bugs now. I've only been able to drive the car once since I was have some issues with the clutch hydraulics. After replacing the slave and master cylinders, I am able to actually get the car in gear at a stop, although I still have some bleeding to do. Anyway, the issue I am having is my brake light on the the dash is on, I have brakes, no fade, I have bled the brakes, still on, jumped the switch under the dash, still on, bypassed the e-brake switch, still on. I did change the rear gears to 4.10s but pcmforless did the tune and I made him aware of the change, speedo seems to be working right. I am out of ideas. Any thoughts?
Old 05-02-2008, 08:15 AM
=Tac='s Avatar
Might sound dumb but did you check your fluid level?
