Rocker Arm Install..?
I was wondering if there was any way to keep the rocker arms from twisting as you tighten them down or if it was just something that is going to happen?
I hold em steady with one hand and use a 1/4" air ratchet in the other. Then torque to spec. There is a sequence and procedure you are supposed to use. Find TDC. Tighten certain ones , spin the crank 360 and torgue the others. I wonder how many people on here actually follow it. Some local guys watching me do it the other day were sayin they have never heard of that and they have done cams before
Good luck.
Good luck.
