QA1 Coilovers?
Old 05-02-2008, 01:14 PM
Restricted User
Zero4488's Avatar
Default QA1 Coilovers?
So now that I'm getting my rear down I wanna finish my rear suspension. I was thinking about a set of the QA1 single adjustable coilovers. I was just curious to hear about the goods and bads of the coilover conversion. Also if I go with the coilovers what kind of suspension should I run up front?
-Dave
Old 05-03-2008, 07:49 AM
Restricted User
Zero4488's Avatar
Any input would help...
Old 05-05-2008, 11:37 AM
lt1noob's Avatar
i dont know from personal experience, but ive heard good things.
Old 05-05-2008, 12:14 PM
DopdBrd's Avatar
Is there any reason you want coilovers in the rear? I have QA1's in the front and they are essentially coil overs because you can adjust the height of the car with the spanner wrenches. After I put them on I adjusted the height, had the car aligned and now it will probably never be adjusted again.
On the rear I am going to stick with stock springs like I have now and just run the single adjustable QA1's. I don't really think there is a need for coilovers in the rear.
Old 05-13-2008, 09:14 PM
phoenix's Avatar
i would like to knwo more about this, i would like to add coil overs for my drag setup, so i can adjust it to what tire size i want to run and when i ride on the street or strip
Old 05-14-2008, 08:42 AM
ThumperNC24's Avatar
i hope this is for a drag only setup.
I also don't see the need for coil overs in a drag setup (or even a street setup really).
just use drag springs or stock springs and QA1 shocks if you are looking for a drag only setup.
Quick Reply: QA1 Coilovers?
