D1 Twin Intercooler, Procharger Guys with SD Tunes!!
Old 05-02-2008, 10:52 PM
D-Webz's Avatar
Default D1 Twin Intercooler, Procharger Guys with SD Tunes!!
What are you guys using for tubing between the plenum and the throttle body with the mass air flow gone. I have been searching in vain around local parts stores for some sort of 4 in tubing to run.
Thanks in advance guys
[IMG][/IMG]
Old 05-02-2008, 10:57 PM
firehawk618's Avatar
Why not just gut the maf and leave it in for the time being.
Old 05-02-2008, 10:59 PM
D-Webz's Avatar
I fabbed up a spacer tube for the time being. It works good but looks like crap.With the mass air sensor in there it restrict the tubing because it smashes the tubing attached to the TB.
Old 05-03-2008, 08:06 AM
AFASTYZFR1's Avatar
I made one out of aluminum pipe and put my meth nozzle and iat sensor in it ...then powdercoated it.....I have some extra pipe in my garage somewhere....I will look
Old 05-03-2008, 07:20 PM
D-Webz's Avatar
Bump for more replies....
Old 05-05-2008, 07:54 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Ditch the physical MAF and create a spacer and then get ti power coated for $10 to $15.
Keith
Old 05-06-2008, 07:18 AM
BLNLS1/RX7's Avatar
[IMG][/IMG]
You need to get hold of Bob at EPP.They sell and install more ProChargers than anybody and they are the BEST.
Old 05-06-2008, 08:44 PM
shiftinda93z's Avatar
when i had a 93 LT1, I put a 94-97 CAI on... and used a MAF spacer that my neighbor that works at a metal fab shop made... he rolled up a piece of 12 ga. stainless and welded it. I put the weld on the bottom, and it looked REAL NICE!!
Old 05-06-2008, 08:48 PM
nvmy2000ss's Avatar
Hit up your local exhaust shop they should have something you can use.
Old 05-07-2008, 12:00 AM
D-Webz's Avatar
Thanks,
Bob is who I got my stuff from, I hope he chimes in I am sure he has experience With SD tuned cars.
Old 05-07-2008, 12:02 AM
D-Webz's Avatar
I actually did that I got some three inch SS tubing and fabbed up a spacer were the MAS air sensor would have been. I was looking for a more direct tubing setup from the plenum to the TB, as my setup right now looks kinda crappy.
Thanks for the response BTW.
