Spec pressure plate + ram disc
Old 05-03-2008, 01:25 PM
DarkCloud's Avatar
Default Spec pressure plate + ram disc
Hi, i'm a broke student.. and recently my clutch went, i dropped my tranny yesterday, and my plan was to reuse my pressure plate, and flywheel (they look really good) with a ram stage 4 clutch disc that was given to me.. i dont have the $500 for a new clutch. my question is if the pressure plate and disc are compatible with each other?? like clearance wise and all..
Old 05-03-2008, 05:15 PM
BALLSS's Avatar
it will work if you are in a pinch. RAM 4 is pretty aggressive disc so you may experience chatter.
Better to do entire new PP, disc and resurface flywheel.
You can also get a reman flywheel for $35 with your core from Kragen, etc. If the disc is new might want to do that.
Old 05-04-2008, 07:25 PM
DarkCloud's Avatar
its a used pressure plate, used flywheel (fidanza, so if i was to do anything i would just buy a new friction surface) and its a used friction disc. i just wanted to make sure it would clear.
Old 05-04-2008, 10:57 PM
CaMaRo67RS355's Avatar
LS7 in ur case
Old 05-05-2008, 11:58 AM
DarkCloud's Avatar
what do u mean? i dont have any money.
