PRC 5.3 TR224 Results....
So I finally had my car dyno'd after 4 months of waiting after my H/C swap. I have a 98 6-speed with PRC 2.5 5.3's and a TR224 on a 114 LSA, LS6 intake, ported TB, 42lb injectors, and all supporting bolt-ons. Also have a TSP catted-Y with Pacesetter LT's and a dual dual catback. I did a best of 395/375 after 9 pulls. I was hoping for a little more but guess I can't be disappointed. Does this sound about right???? Any ideas where I could gain some more power? I was thinking maybe cutouts??
Thanks for your input.
no dyno queen, but doesn't seem far off to me with the mods
stock rearend?
stock gear?
if you are looking for a bit more power remove the cats, get a cutout & I'm sure you would see 10-20 rwhp
stock rearend?
stock gear?
yes..all dyno's differ and that's why I didn't say it is too low
We have had a few on our dyno here and there that are 20-30 lower then norm with a particular combo, but they run as good if not better then the higher dyno cars at times.
did you pre-dyno the car? We try to do this a lot more now since some just start lower, but the gains are all the same at the end of the day.
I would say maybe 10ish with a 90/90 with this milder combo.
get it to the track and see how it does
LS1Tech Premium Sponsor
With cats & through the exhaust it's still a little bit lower than I would guess. What compression did you set it up with? You might consider putting a cut out on it just to see where she's at with a good exhaust.
What kind of air fuel & timing did she have?
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Jason
2005 Twin Turbo C6
Yea,
I felt it was a little low myself. Im not too concerned, but Im not going to lie I wanted to break 400. Im not sure where the AF ratio was but I do know the timing was at 27.
Im going to take the car to get dyno'd again. This time ill take off the 19 inch c6's with runflats and run the car cool. The 395 was after 9 runs on the dyno, so I think I might have lost some power with the heat. I'll keep everyone posted on the new numbers
It could be that the dyno is running low numbers too,
I've been on different dyno's and my lowest is 364HP/362ft/lb
On another dyno was is 372HP 370ft/lb.
And just after the cam install and tuned are the numbers in the sig.
