Pat G Torquer Cam Installed!!
Holy crap, I'm MORE THAN HAPPY!!!!
This cam is VERY, VERY streetable!!! It inly chuggs in first when you're trying to creep, but other than that it hardly chuggs at all! Very tame when you're not on it, even in the un-tuned state as mine is in (Waiting on TR to get back to me about the tune)..
Anyway, I took it out in the middle of the empty desert earlier this evening to see what it had... HOLY **** I WAS SHOCKED!!!!! From a U Turn Turn around, 1st and 2nd were fast as usual, 4th went just as fast as 3rd, I shifted to 5th,looked down and I was doing 140!!!!! It seemed to take about 10 seconds..
H/C INSTALL MODS
LS6 P+P'd Heads
ARP Head Bolts
Patriot Dual Gold Valve Springs, Titanium Retainers and locks
New NGK TR55 Plugs
MSD Superconductor Wires
Comp Cams 7.400" Chromemoly Pushrods (measured correctly)
Comp Cams Hex-adjust Timing Set
ARP Cam Bolts
Thunder Racing Ported LS6 oil pump (50 PSI oil pressure at idle, w/ thicker O ring too)
Thunder Racing Custom Grind Torquer Cam 224/228 .637 .640 110LSA +0
ASP Under drive pulleys (on back order... Darn it all)
On to the good stuff... Only one vid so far... Fresh install..
Exh clip..
http://www.youtube.com/watch?v=YHVL1DVLCEE
H/C INSTALL MODS
LS6 P+P'd Heads
ARP Head Bolts
New NGK TR55 Plugs
ARP Cam Bolts
Exh clip..
this is sweet music to me..i just recieved my patric-g cam my self... very close to yours 226/230-111 .610/.605 the LS1 with this cam should be a tad bit faster than the bone stock 267sbc in the car now
Hey, I'm doing an engine rebuild right now........Well, i have a mechanic doing it. I want to go with a larger cam but nothing too crazy. What one should I go with?
