Gears & Axles - 10 bolt posi question...
JGoodin86
05-04-2008, 12:19 AM
I have a 98 Formula with 2.73s. The posi isnt working and I want to go to a steeper gear. I found a 3.42 rear end for $50. But it has a bad spider gear. It is out of a 2000 ss.
What kind of posi do I have in my 98 Firebird? Does my 2.73 rear end have the same spider gears, or is it a different type of posi?
Thanks for the help.
JGoodin86
05-04-2008, 10:08 PM
Ok, i am pretty sure my 98 has a auburn. So if the 3.42 rear end has spider gears, it has to be an auburn also.
Will spider gears out of a 2 series fit in a 3 series carrier?????
JimsWS6
05-04-2008, 10:20 PM
I thought I've read before the newer cars had a different limited slip. I'm not too sure, you'll have to wait for a more knowledgeable person to chime in
ta_06374
05-04-2008, 10:33 PM
There are different...I found this out the other day when I removed the covers. 98 vs 99 and up.
FirstLSx
05-04-2008, 10:37 PM
99+ is Eaton
JGoodin86
05-05-2008, 04:52 PM
99+ is Eaton
Are you sure????
JGoodin86
05-05-2008, 04:58 PM
This guy was selling an auburn rear out of a 2000 ss, so I dont think that is correct. I dont think any 98+ f bodys came with eaton stock.
http://ls1tech.com/forums/showthread.php?t=900734
They are either auburn friction type, or torsen worm gear type.
Anyone else know...
keliente
05-05-2008, 05:08 PM
99+ is Eaton
No it's not.
dailydriver
05-05-2008, 05:22 PM
Anyone else know...
You are correct. The SSes (and Firehawks as well, I believe) were offered from SLP with the option of an Auburn (Pro??) instead of the stock Torsen T2.
'99 and up, Torsen T2 stock.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
