LS2 Starts sometimes
Old 05-04-2008, 12:30 AM
Midnight68's Avatar
Default LS2 Starts sometimes
LS2 conversion in a 68 Camaro, I got it ready and cranked and started it today. It starts sometimes and idles and runs just fine. Then cranking it the next few times it wont start it just turns over and backfires. Any ideas?
Old 05-04-2008, 07:53 AM
rao
rao's Avatar
I'd check out the cam sensor wiring.
Old 05-04-2008, 08:00 AM
john 67's Avatar
had a friend with a similar problem an an lt1, turned out to be a voltage problem JOHN
Old 05-04-2008, 09:46 AM
Midnight68's Avatar
I dont know about the cam sensor, its the original harness off the motor that I had modified, so I doubt its a wiring problem.
When you say voltage do you mean voltage to the computer or??
Old 05-04-2008, 10:37 AM
JAY ROD's Avatar
fuel psi.check regulator.
