WTT :TH350 Swap for T56 or 4l60e/4l80e setup
Here's what I got:
TH350 Swap -
TH350
Hughes Lightweight SFI Flexplate
Turbo 350 Manual valve body (built to 900hp)
Custom built 9" tail shaft with magneto reluctor wheel (so that your speedo works) The 9" tail shaft also allows the use of the stock driveshaft.
B & M Tranny Cooler
Hughes 4500 Stall (Flash stall tightened down)
B & M Pro Bandit Shifter w/ pistol grip
Tranny Cross member (already fabbed)
Tranny Dipstick
Torque Arm Mount (B & M)
Automatic pedal configuration
Will also include a 2800 stall with this setup that I wont need if I trade.
T56 Only - Need a M6 so I can sale this beast!
Price if interested in buying - $2000
TH350 Swap -
TH350
B & M Tranny Cooler
Tranny Dipstick
i have a T56 from a 1995 trans am. it shifts great i have run royal purple oil in it since i got the car it has the factory hurst shifter with a white pool ball shifter and a gun handle i will include. i also have the stock flywheel and replaced stock clutch, the clutch has alot of life left on it please call me for more info and pics call ben at 618 334 1321
