Generation IV External Engine - LS7 headers
View Full Version : LS7 headers
ss dave
05-04-2008, 12:13 PM
Looking for 1 7/8" headers for the 69 Camaro, LS7 D shaped ports. Anyone know of any? Thanks
Order 66
05-06-2008, 07:50 AM
Custom :)
71CamaroLS1
05-06-2008, 08:56 AM
American Touring Specialties ($$$$$$):
http://store.nexternal.com/shared/StoreFront/default.asp?CS=ats&StoreType=BtoC&Count1=234966456&Count2=152106881
Or, modify a set of 4th gen Kooks headers. Scott Gulbranson, the guy who runs lateral-g.net, did that for his '69. Do a search on the forums there ...
Stang's Bane
05-06-2008, 09:17 AM
correcto mundo. he only had to modify one primary on the drivers side.
he used Kooks for what it was worth.
FWIW, if you can find a set with round flanges, I wouldn't be overly concerned about using them...
ss dave
05-06-2008, 01:06 PM
Thanks, I checked with Tyler at ATS, $$$$$ and Stainless Works $2200. each! Looks like I'll stay with the Hookers.
71CamaroLS1
05-06-2008, 02:08 PM
LG Motorsports has built quite a number of Z06/LS7s with over 600 RWHP, using their 1-3/4 headers, so I wouldn't worry about losing much with the smaller tubes. You have to remember, the LS7 only has a 1.60 exhaust valve, so beyond a certain point a larger header tube buys you nothing in terms of flow and costs you in terms of scavenging.
VictionOne
05-07-2008, 12:25 AM
ss Dave,
Check with Frank @ Prodigy Customs. He has LS7 1 7/8" headers in the works for about $1200-1400. They were prototyped off of my car which has a DSE subframe and an LS7 but will also fit the AME subframe.
ss dave
05-07-2008, 03:12 PM
Thanks, I know Frank, having spoke with him several times. I have a modified stock front clip. We notched the crossmember to accomodate a Canton oil pan. My LS7 is a wet sump with ported exhaust, that's why I would like to find a set of headers. Take advantage of the head work.
ss dave
05-15-2008, 01:10 PM
I talked with ARH and Nick, they are going to do a prototype with a 69 Camaro LS7 in the next few weeks! Everything from 1 3/4 to 2". Hope others will follow suit-otherwords this is a shout out to KooKs, Stainless Works, Hooker-(please upgrade your stuff!)
