Fueling & Injection - quick racetronics fuel pump question?
curtisad
05-04-2008, 12:35 PM
Can a rubber fuel line hose be used inside the fuel tank? I managed to break the supplied plastic hose that goes from the pump itself to the top of the sending unit. That sucker is a TIGHT fit to say the least!!
2thousand2
05-04-2008, 12:55 PM
You could use it for a while, many have...but long term I would think you should drop the tank and check it. Maybe every couple years or so. Make sure the fuel hose you use is high pressure fuel injection hose (it will last longer than the cheap stuff).
BOTTLEFEDLS1Z
05-04-2008, 07:35 PM
What about the stock one that you had to pull off to replace with the supplied one?? I'd just use that if you can
94m6Z28
05-04-2008, 08:50 PM
what do u mean its a tight fit?
my racetronixs system shows up 2morrow...soo a heads up wold be awasome
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
