Generation IV Internal Engine - Can i install the Heads and then install the oil pan and covers After
BadLtBlu99TA
05-04-2008, 03:58 PM
My question is can i install the lifters with lifter trays then install the heads before i install the oil pan and covers and oil pickup tube oil pump ect ? or is there a certain way i should go about this ? just wonder..
Will part # 134-3610 work for TSP 402cid engine ? need advice asap , thanks .. i dont have ARP lube , so will oil work ? thanks ..
socmguy
05-04-2008, 08:50 PM
Yes, you can assemble it that way,
don't know if that part will work,
oil will work if you don't have arp lube
Randy WS6
05-04-2008, 09:02 PM
There is a different torque spec with the oil, go to ARP web site to see.
DrkPhx
05-04-2008, 09:12 PM
That is the same head bolt kit I use. Even though you can use motor oil, I seriously recommend using the ARP Moly lube. The bolts torque much smoother and easier. If you do use oil, keep in mind the torque spec is higher.
BadLtBlu99TA
05-04-2008, 10:23 PM
thanks all .. appriciated it !!
BadLtBlu99TA
05-04-2008, 10:31 PM
i got my Head bolt kit and it didnt have any ARP Moly Lube in the box , how could i get this ? FAST ??? i need this stuff ASAP !!! like tommorow Afternoon !!
DrkPhx
05-05-2008, 08:14 AM
A local speed shop should carry it. Summit Racing (in Ohio) also has it.
Randy WS6
05-05-2008, 11:03 AM
I got a bottle of it from Summit for 19.00 but you can get the little packet to alot cheaper
czwalga00gt
05-05-2008, 01:17 PM
Jegs is in columbus.
socmguy
05-05-2008, 01:46 PM
yep, Jegs/Summit will ship it fast as hell!
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
