SIMPLE cam
SIMPLE cam
alright i REALLY want to throw a cam in my 98 t/a a4. but i know its alot of work . so im looking for some suggestions on an extremly streetable cam with minimal work. oo yeah and on a budget. thanks!
i like my 224/228 (check link in sig for dyno ) . Very streetable compared to cams I have had in the past . Makes good power as well as a nice note . You cant go wrong with a LS6 cam as the yellow springs are pretty cheap but you can get some 918s for a little more coin and have a wider variety of options for the future .
I've got a nice cam that would work great in your car. But you would also need to get a valve spring kit, hardened PR's, and all the front acc gaskets. So look to be spending about $500-$700 if you were doing a cam swap. Thats for a cam that will actually make good power.
Keep your eye on the classified section here. You can pick up a used cam, spring kit, and pushrods for cheap. Then all you'd have to get new would be gaskets and a balancer bolt. Since you want something simple and super streetable you probably won't want anything more than a 224ish cam.
