Small Block & Big Block Chevy Specific Mouse & Rat Motor Discussion & Conversions
chevy small block
Old 05-04-2008, 08:33 PM
92builtbird's Avatar
Default chevy small block
Is it possible to do a 4.125 inch bore and a 3.75 inch stroke in a chevy 283, to make 400 cubic inches?
thanks!
Old 05-04-2008, 10:17 PM
In-Zane Moderator
ZONES89RS's Avatar
Not no but HELL not.
Z
Old 05-10-2008, 11:25 PM
1994z's Avatar
second the no, but you can bore your 283 .125 over with stock stroke. leave the line at 8000 rpm shift at 10,000.
Old 05-11-2008, 12:24 AM
SMALLBLOCKHERO's Avatar
you need an aftermarket block with siamese bores to acheive that bore size.
Old 05-11-2008, 10:17 AM
6 & 8 Second Club
mrdragster1970's Avatar
The only chevy block that will take a 4.125 bore is a 400. If you have a 283", try selling or trading to a restorer.
Someone that needs a number matching 283". Than get a 400 or aftermarket block.
Old 05-11-2008, 05:26 PM
RAGENZ28's Avatar
I ran my 400 block with a 4.145 bore, you can go 4.155
Old 05-11-2008, 11:31 PM
In-Zane Moderator
ZONES89RS's Avatar
Mine is 4.165.
Old 05-12-2008, 12:01 AM
RAGENZ28's Avatar
.40 over on a stock 400 block
Old 05-12-2008, 03:03 PM
In-Zane Moderator
ZONES89RS's Avatar
Yea, you can go .060, but you are not going to last long usually.
Old 05-12-2008, 07:56 PM
slow95z's Avatar
you could bore your 283 to 4.125 but you would catch hell keeping water in it and not in the oil pan. the 400 can be bored out a good bit because most of the time its filled with hardblock and you're only wanting to make it a 1/4 of a mile from where you are. you really wouldn't want to get stuck in traffic with a stock bore on a hot day with a well built motor with a 400 though.
