Fueling & Injection - Racetronix harness relay - brake line interference
mean02Z28
05-04-2008, 08:35 PM
Has anybody successfully mounted the Racetronix harness 40 amp relay to the brake line bracket on a 4-channel car (ASR+ABS)?
On my car the relay significantly interferes with the brake lines. I've searched for some pictures, but only found a few of the relay on 3-channel cars (ABS only). I'm thinking I'm going to have to drill a hole in the frame rail (which I'm not keen about doing) and secure the relay above the brake bracket. If I don't do that, then I will probably have to modify the brake lines somehow.
Let me know what you all did.
Chris
Racetronix
05-04-2008, 11:46 PM
Chris
Have you tried to contact support@racetronix.com or a dealer with your problem and contact details?
mean02Z28
05-07-2008, 11:19 PM
Email was sent on 5/5 to support@racetronix.com. Still waiting on a response.
