Transmission shifting too early in drive
My transmission is shifting too early off the line when i leave it in drive. It goes great out to the 60ft mark then just boggs and then takes off slowly like it is in too high of a gear and ran a lowly 8.2. I shifted it manually on the 3rd and 4th run and if ran perfectly back down to 7.5, 7.4, just inconsistant with my shifting without a light. The tuner said the shiftpoints are at 6500rpm. What would make the car shift so early. I am getting good burnouts with the MT ET Streets. I believe they are hooking up. I did see a low traction light on at the end of the track a few times. I had the TC off on all runs. Is there any way for the Traction Control to kick on. Should i pull the fuse on it? I don't think that is it as i do not have the throttle cable going to the box anymore, i replaced it with on directly to my TB. Any ideas, advice, similar problems?
