tranny shops/experts come in please
Old 05-04-2008, 09:05 PM
regency's Avatar
Default tranny shops/experts come in please
how the heck do you remove the pump from a 4L65E i know you have to remove the bellhousing but what else and how????
Old 05-04-2008, 09:30 PM
LS1Tech Sponsor
performabuilt2's Avatar
the lockup solenoid in the case and the bolts and technically use a puller but you can tap it out with a brass drift from behind
__________________
https://ls1tech.com/forums/image.php...ine=1194732633
Free Cooler, Free shipping always, 2 year warranty Trans/Coverter combos, No Core or Core charge, $150 LS1 core buy back, All trans Dyno Tested to Be sure it works when you get it.Customer videos, Tech Thread, Open 7 Days a Week! Call or http://opi.yahoo.com/online?u=performabuilt&m=g&t=2Click Banner for Website.
Not Just Built.....PerformaBuilt!
Old 05-04-2008, 09:55 PM
FLT
FLT's Avatar
You need to remove the pan, lock up solenoid, filter, pump bolts and then with the use of a pump puller remove the pump. Or use a screw driver and pry the pump from the case. Be careful not to damage the case while doing so. The best place to pry the pump out is between the filter seal area of the pump and the reverse input drum. Here is the area that is best to pry in. Hope this helps. Vince
Old 05-05-2008, 07:01 AM
regency's Avatar
cool thanks
Old 05-05-2008, 05:13 PM
LS1Tech Sponsor
lol yeah pry thats what i meant to say I was working on a 518 when I made the post and was tapping the pump out lol sorry.
__________________
Old 05-05-2008, 08:07 PM
regency's Avatar
Does $250 to $275 sound right to bring it in and change pump with a new one and they do it
Old 05-05-2008, 08:23 PM
LS1Tech Sponsor
sounds like a reman pump labor is about right
__________________
Old 05-05-2008, 08:31 PM
regency's Avatar
well they said like $190 for pump PWM and like $60 for labor
Old 05-05-2008, 08:56 PM
LS1Tech Sponsor
yep about right
__________________
Old 05-05-2008, 09:12 PM
regency's Avatar
thanks!! your the man!!!
