Headlight Motor.
Old 05-04-2008, 10:23 PM
Coppertone's Avatar
Default Headlight Motor.
So my driver side headlight makes the grinding noise for about 5 seconds after I shut the lights off.
Can I just buy the brass gear, or do I need the whole motor?
Old 05-05-2008, 11:04 AM
topdj-com's Avatar
not to be a jerk or anything But I think the sticky above will give you the info you need
Old 05-05-2008, 02:27 PM
snake charmer's Avatar
you could tyr to turn the gear manually to the side of the gear not used .
Old 05-05-2008, 04:57 PM
Cape T/A's Avatar
use the sticky thread, but what i have found is the brass is only just a tempory fix. you have to make sure that the metal clips on the motor are extremely tight to the plastic gear housing, if they are loose even the metal gear will strip. if i could do it again, i would have skipped the brass gear and just put in a plastic one that can be picked up from Napa for 12 bucks. o-yah, all you need is just the gear though.
Old 05-05-2008, 11:04 PM
Coppertone's Avatar
Aww **** guys, I'm sorry. I didn't even see the sticky.
Sorry!!!!!!!!!!
Quick Reply: Headlight Motor.
