Fueling & Injection - injector size ?'s
View Full Version : injector size ?'s
rich
08-05-2003, 04:56 PM
I am building a 422 cuin steel block engine it should be near 500 rwhp all the injector calculators say a 42 lb injector should be fine. I see people with the same hp with 36 lb injectors. I have a set of 42lb svo injectors is this a good starting point or are they too big or too small?
Pro Stock John
08-05-2003, 04:58 PM
They are rated 42lb at 43psi right?
I had a 422ci and ran injectors that were 39.5 @ 58 psi and I made 475rwhp and had room up to 525rwhp supposedly.
rich
08-05-2003, 05:00 PM
yes they are 42lbs at 43psi.
Pro Stock John
08-05-2003, 05:04 PM
So 42 @ 43 works out to being __? at 58?
MTI uses 36 lb SVO's.
ArizonaSpeed
08-06-2003, 11:45 PM
I would say the 42's would flow 56 lbs/hr @ 58 psi of fuel pressure.
Joe Overton
08-07-2003, 12:04 AM
John roughly a 48# it equates to
