Will Stock Slave Work With Ls7 Clutch?
Old 05-05-2008, 07:45 AM
SLP Firehawk's Avatar
Default Will Stock Slave Work With Ls7 Clutch?
i dont know if this was answered in the other threads but will the stock slave work with the ls7 clutch set up. and if i'm correct i dont think you need to use a shim with the ls7 set up do you?
Old 05-05-2008, 10:02 AM
67rsss's Avatar
We don't have a shim on ours, and it works great! Ours is a new slave however, to cheap to not change it when the trans is down.
Old 05-05-2008, 10:33 AM
No I'm Going To Get A New Slave Just Oe For The Ls1, I Dont Need An Ls2 Slave Or Anything Do I ? And How Comes The Ls7 Doesn't Need A Shim?
Old 05-05-2008, 11:22 AM
_JB_'s Avatar
ls1 slave.
Old 05-05-2008, 11:58 PM
Z28/2002's Avatar
Location: Your girl's back door giving her the long stroke while you're at work
You still run the LS1 slave and you don't have to use a shim
Old 05-06-2008, 06:06 AM
Ok Thanks
