s10 fuel gague correction (ls swap)
My 02 s10 uses the same 12200411 pcm with the LS as it did with the factory 4.3 v6. I am using a pcm flashed for an 02 camaro. Using hp tuners is there any way that a tuner can access the factory s10 fuel gauge info from my original pcm that has been untouched and copy that over to my new pcm. I would love to get my gauge to work correctly. Thanks
Does the factory fuel gauge work at all (display wrong) or not at all?
looking at the 2 files, somehow it should be possible, since they run the same OS (if your running 12212156. But depending on what is working now, it will depend if hptuners can do it or not, or if it is in a section of code they do not support.
Ryan
Ryan
