Fuel Issue
Old 05-05-2008, 12:40 PM
qakhntr26's Avatar
Default Fuel Issue
Ok I am need of some help. I have a 2002 WS6 that I have installed. I start it up and everything is good. I can run RPMs up no problem. I can drive with no issue except when i come to a stop it will idle down and shut down (this also happens after warm up at an idle. I am running a aeromtive pump AEI-11109 325GPH 45 PSI with a Race Pump Regulator, Fast Rails with stock injectors. Any Ideas?
Old 05-06-2008, 10:24 AM
Bill Bowling's Avatar
What is your fuel pressure at the rails? It should be around 58 psi.
Good luck.
Bill
Old 05-06-2008, 12:37 PM
qakhntr26's Avatar
Default Fuel Issue
Do not know that right now but I am installing a gauge later.
