What Is It....
What Is It....
What if you just changed to a th350 and the first 4 or 5 runs it done great. then change to another stall ran it 3 times and on the fourth pass i stalled up at the line and when i left it just boged down untill about the 60ft mark and then takes off like i shot it with nitrous.........It will not even do a burn out now....... It has a trans brake and a vig stall..Do you have any ideas what it might be......trans,converter or TUNE .........I have it on my trailer now and i can put it in first and try to power brake it the rpms will go up to about 3000 but that is it and the tires will not turn over.......
