A body fuel lines
Trying to plan ahead, going to Chevelleabration and will me ordering new lines for the car and need to know if I should get new factory style lines or make other plans...Thanks.
Does the fuel line for the 6.0L come up on the pass side like all Sb,BB's? Thanks for the help...
Rick
Rick
I did a frame off on my project.. so I was able put in new 3/8" Stainless Steel hard line in the stock location.. I then flipped the fuel rail 180 and connect it up with the usual AN fitting and SS Braided hose. No problem...
If I was going to do more racing or pumping up the HP. I might have done 1/2", but it is just a cruiser...
I know when I bought the FFR from the parts store the guy was showing me these plastic pieces that press on which I did not want. I figured I would just use comp. fittings instead but I would like to hear you thoughts/finding with the style you have.
Thanks,
Tom
That's what I was needing to know, about whether to put new SS lines back in it in the stock locations, bczee, did you use the stock return line on your 71? I can't even remember if my 71 has a return line on it? I haven't started this project yet, just trying to get things lined out b4..
Rick
Rick
So I'm looking at your install bczee, and it looks great. Matter of fact, it's been excellent reference and inspiration for my install of 2002 vette ls1 into my 71 chevelle. Couple questions...I attached one of your pics...on the filter, isn't the outside the larger size line, that the pump output should feed? Am I seeing the connections incorrectly?
So the fuel pump has 3 connections, pressurized supply, return, and vent in that order (I think?) Looks like the vent goes to the looped lines that are behind the back seat...where does the other end go? Don't guess you have a diagram of the plumbing, do you?
Thanks
Rick
Thanks
Rick
Yeah.. busted.. When I was putting it all together.. I had connected the wrong lines..
I found out about it after I tool the pictures when the pressure would not build up on the gauge on the fuel rail.. I then switched the lines and all was good. Good catch on the picture.. your really doing your research !
