Help Please with P0351 thru P0358 Codes
Old 05-06-2008, 11:07 PM
gyan's Avatar
Default Help Please with P0351 thru P0358 Codes
I'm getting a; Powertrain ignition coil 1 tru to coil 8 control circuit codes can anybody help me with this? It's on an LS1 2002 Camaro. The car just dies all of a sudden, it recovers after about 15 minutes with the hood up (I guess it must be an engine heat related issue??) A couple of times it recovered by itself with only a momentary loss of power & it backfired once. Crank sensor ? The cam position sensor was changed about 3K ago with an unrelated issue. I thought it was symptomatic with a coil going bad but not all 8 at once !! Could the power wire to the PCM be intermittently open? ANy help would be MUCH appreciated.
Thanks
Old 05-07-2008, 01:54 AM
proelky's Avatar
Is your car stock?
Old 05-07-2008, 06:49 AM
gyan's Avatar
Well the engine is stock...it's in an RX7. It was running great since I got it on the road about 3K ago.
Old 05-13-2008, 02:35 AM
gyan's Avatar
No help here?? It kinda starts during IGN 2 "START" position so I'm guessing that IGN 1 has no power. Anybody got a wiring diagram of the IGN 1 circuit ??
Old 05-15-2008, 10:12 PM
XtremeLS1's Avatar
check the wiring to the coil packs. wiggle the wiring to each coil while the vehicle is running and that will determine if it is a wiring malfunction off the pcm. check that first...
Old 05-16-2008, 02:25 AM
gyan's Avatar
Thanks I'll try that. Also I'm thinking of putting a bulb on the Ign run position to see if it goes out during the ignition control circuit issue. If it goes out, I hope it does... then the issue will be much easier to track on the power side of the circuit.
Quick Reply: Help Please with P0351 thru P0358 Codes
