Can I get a quick easy answer?
Old 05-07-2008, 12:24 AM
slp--firehawk's Avatar
Default Can I get a quick easy answer?
Im lookin to hook up coolant, where should i get it and return it?
slp--firehawk is offline
Old 05-07-2008, 09:44 AM
Dumb Ass Vette Moderator
ls1290's Avatar
Collant for what?
Keith
ls1290 is offline
Old 05-07-2008, 10:38 AM
LS1Tech Sponsor
Superman09's Avatar
i think he is referring to water cooling for his turbo(s). Like the APS kit does..... it gets coolant from the rear pass side head, and drivers side of engine block (Huge plug). Check out the APS install guide on their website to see the exacts but pass side turbo has lines ran from the rear of pass side head, then other fitting is a crossover to the fitting on the drivers side turbo. Then the other drivers side turbo fitting is ran to the drivers side of engine block fitting. Hope this helps!
__________________
Featuring 6 different turbo kits for your F-body!
Check us out on Facebook at: www.facebook.com/HuronSpeed
Superman09 is offline
Old 05-07-2008, 10:53 AM
Zombie's Avatar
You could use the heater core line from the water pump (smaller line) since there is no valve it is constantly flowing. I have a temp sensor spliced into this line and it reads the same as my factory coolant sensor.
Zombie is offline
Old 05-07-2008, 12:33 PM
BLNLS1/RX7's Avatar
WHAT?
BLNLS1/RX7 is offline
Old 05-07-2008, 12:37 PM
yotaman96's Avatar
At first, I thought he was asking where to buy it and how to dispose it.
yotaman96 is offline
Old 05-07-2008, 02:56 PM
LMAO. Alright good comments, thanks. Sweet now I get to squeez between the firewall and back of the engine hmm or maybe ill check out the heater core line first and see.. Thanks.
