FI Guys, Whats Your Trans Of Choice?
Old 05-07-2008, 01:06 AM
Sold The Fun Stuff :(
josh99ta's Avatar
Default FI Guys, Whats Your Trans Of Choice?
Toying with ideas for my GTO and had some questions. I've noticed a lot of people go from M6 H/C/I setups to trans swaps over to the A3 or A4 side with a turbo setup. I see a lot of M6 supercharged setups more than I do auto s/c setups. So just curious what your favorite trans of choice is on your FI setup, what FI setup you have, and what is your primary use for the car (fun street car, drag race car, road race car, etc).
Old 05-07-2008, 08:38 AM
John_D.'s Avatar
With the s/c, the boost is rpm dependent not load dependent, so a manual is equally suited to the task as well as an automatic.
With a turbo, you need load in addition to rpms, to generate exhaust gas to get spooled up, and I like an automatic with at least a 3k stall for that. You know the story on my car -- built to do it all, street/drag/ax/rr.
Old 05-07-2008, 10:00 AM
Photochop's Avatar
Agreed with above, and if you like the idea of shifting, get a 4l80e built with a full manual valvebody with a transbrake as well. Then you get all the benefits and features of both plus more.
Old 05-07-2008, 10:08 AM
bluebeast's Avatar
built T400 with a good qaulity torque converter..... i have an old school artcar that does the job! some guys can have a M6 built to handle big power but its really hard to be the reliability of a T400!
Old 05-07-2008, 10:55 AM
Zombie's Avatar
TH400, faster and more fun than my M6 could ever dream of being, hard to beat the reliability as well.
Mine is a fun street car (really fun). 2.75 gears = decent gas milage and good highway manners.
Old 05-07-2008, 11:17 AM
nossty1's Avatar
TH400 hear aswell!
Old 05-07-2008, 11:18 AM
JMBLOWNWS6's Avatar
4l80 Here
Old 05-07-2008, 11:19 AM
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,089 Likes on 717 Posts
TH400 for racing, and for some street driving.
Old 05-07-2008, 11:29 AM
cablebandit's Avatar
4l80e...fully electronic with rossler tbrake so it acts/ahifts like stock on the street. If only going to the track only, i'd say th350,th400, or glide...depending on weight/power
Old 05-07-2008, 11:35 AM
Websy21's Avatar
Agreed with all of the above, I love grabbing gears so I had a Viper Spec t56 built allong with a twin exoskel but before I even had a chance to install it I sold it and just finsihed getting a 4l80e built with a custom 3k stall. This is for a turbo btw.
Old 05-07-2008, 11:48 AM
bluebeast's Avatar
yep but this is the forced induction area so i figured he would be racing and hot dawging and plus if you get the right converter and gear a A3 can be very streetable..... i mean how many guys are taking these FI hot rods on cross country vacations anyways? but you are so right when you say that but as long as you do an A3 right you can almost have the best of both worlds! the problem is guys try to run BIG stalls with old trannys that dont have lock up stuff so they run alot higher rpm speed at cruising levels than they have to
Old 05-07-2008, 01:59 PM
frcefed98's Avatar
after wasting too much $$$$ on "built" 4l60e's, I finally decided to stop dicking around and go TH400 with 'brake, RMVB....also beefed up the rear with a ford 9 inch from moser.
J
Old 05-07-2008, 02:44 PM
camarols1's Avatar
Figure out how you plan to use the car first.
I will be running 70% track versus 30% street, so a TH400/tbrake is a no brainer.
The turbo builds don't need a crazy gear or converter, so it will still be street friendly.
Guys that drive more on the street will benefit from a 4L80E for better mileage.
Old 05-07-2008, 06:59 PM
-1SLOWSS's Avatar
I am having a great time with the 4l60E and 3500 stall on my SS Josh. You know I take it up in the mountains, on long road trips, cruise through town, and beat on it at the track. I can't shift a 6 speed worth a hoot so the A4 has been great for me. Just mat the loud peddle and hang on
Old 05-07-2008, 07:07 PM
NA$TY-TA's Avatar
Damn My Post didnt show up from earlier........
Well a Glide was good enough for me to hold up at the track and drive everyday.....
If i every build another BADASS STREET car ill go with what Mightey Mouse has...
A built 4L80E.... Drive 800+ miles to the track, get 20 MPG on the way there, Run 8's at the track, Drive 800 miles back home getting 20 MPG and Dyno 1000HP.
Can ya ask for anything more??? and Wieght 3800lbs!!!!!!!
Kyle
Old 05-07-2008, 09:14 PM
best i have gotten is 19.2mpg so far on the highway (last weekend) but I am still working the tune. 408 just drinks more gas than my 346 did.
Old 05-07-2008, 09:22 PM
o2ws8's Avatar
200r4 here
Old 05-07-2008, 09:32 PM
Sideways240sx's Avatar
TH400. I will be getting one hear soon.
Chris
Old 05-07-2008, 10:26 PM
DeltaT's Avatar
Hughes 4L80E with the TCI controller. Love it. Got it set up to shift mellow until you hit 49% TPS. Adding a paddle Shrifter kit which I'm hoping really helps for street and road race driving.
Jim
Old 05-07-2008, 10:29 PM
Websy21's Avatar
Jim
Holly ****, you can't beat that setup IMO!
Quick Reply: FI Guys, Whats Your Trans Of Choice?
