Cam swapped, rocker arm keeps coming loose
I bought a cam from a friend of mine and one of the rocker arms has come loose twice now. Not sure why it's come loose but I've been told that he put some loctite on i to try to prevent it from happening again. I'm not very mechanically inclined and I don't currently have the time myself to learn and tinker with these cars yet so I've trusted it to someone else.
Anyone else have a similar problem to this and could possible tell me why the rocker arm keeps coming loose? Do you think the loctite will work and that I have nothing to worry about? My car is a 2000 SS. Thanks.
Here is the tightening procedure. Loctite should hold as long as there are no other issues causing this, however, you need to clean the bolt hole and the bolt with denatured alcohol or other solvent to ensure there is no oil. Otherwise Loctite will not bond correctly and therefore won't hold.
LSxGuy widda 9sec Mustang
I've had better luck torqueing to 26lb ft to prevent the rocker bolts from backing out. Most torque wrenches are highly inaccurate at the lower 25% of the scale to begin with.
