No more piston slap
No more piston slap
Wassup guys! jus got my car back today from the dealership and no sound of piston slap . all in all they changed o-ring in oil pump, lifters, and bought tr cam package and wahlaaa no more freakin annoying piston slap.The tech pulled and tear apart the motor to check pistons and grooves in cylinders. all ok. all i can say is the tech that worked on mah car is bad ***, did all this within 8 hours.
but one thing my ses light is on now, P0300 (engine misfire detected) guys wit tr224 cam u guys have any problems wit this code when cam was put in? if so pls reply wit wat ever info u got. im guessing could be bad connections from spark plug wires. would love to bring it back to the dealers but they booked till next week. so guys pls reply asap. thanks in advanced
Re: No more piston slap
i've got the TR230 cam and i've never gotten the misfire code, I do get the P0106(MAP range/performance) code all the time though from when it sits at idle too long. Maybe it needs a bigger hole in the throttle body or something to fix it
I know how you feel, I love the sound of my car soooo much more now with out that anoying so called piston slap (is what the dealer called it), I had a tick,tick,tick sound from my valve train and slowly went away untill my car got good and hot, I took it back three times for that anoying sound, My piston slap turned out to be what I beleve my stock lifters, I changed them out during my cam install(basic TR cam package with some extra's) and put in comp R's lifters and now I have no problems with so called piston slap. P.S. my stock push rods checked out good.
yeah the only thing i hear now is the valve train. like chris said sounds like a sewing machine. lbc ss, u dint have any ses after cam was put on, wat size cam u got? does have a hard time starting and idling @ first start?
