Comp Cam sponsor HELP!
LS1Tech Premium Sponsor
Did you order it directly from Comp? If not, you'll likely have the best luck getting your issues resolved by first talking to the distributor who placed the order. If you went direct to Comp, the link and numbers listed above will be your best bet.
__________________
Largest Stocking Distributor of LS-x Engines / CHECK OUT OUR NEW WEBSITE!
COMP - FAST - PACESETTER - DIAMOND RACING - EAGLE SPECIALTY PRODUCTS - CALLIES - COMETIC GASKETS
RAM CLUTCHES - MOSER ENGINEERING - KOOK'S HEADERS - ARP - GM BOLTS AND GASKETS - MSD - NGK
POWERBOND - ASP - AND MORE!
If Comp ground it wrong, then they'll stand behind it. If who you bought it from messed up, they might have to eat it (or you will if you've got my luck). Hope it works out for you!
__________________
Called Comp, left message with Red, no reponse as of yet. (I called at 4pm, so I didn't really expect a call bak today), but I think I have it sold anyway. Losing a little bit of money, but it is better than losing alot of money..
And less headache to just unload it and start over.
Thanks for all your help guys.
